| Posted by Deb on March 07, 2004 at 10:54:22: | |
| In response to Re: Installing new tub | |
: I'm putting in a new tub and the new drain is not over the water waste line. There is a pea trap but it is not located under where the new tub drain is located. Does the pea trap have to be directly under the tub drain or can I run pvc pipe at a downward angle and tap in to the existing pipe where the pea trap is. If so how much pitch do I need per foot in order for it to drain properly? It's about a 3 foot run. The p-trap must be directly under the tub. |
