Re: Pump won't build pressure above 50lb in new pressure tank
Posted by Drew McCann on March 07, 2004 at 10:21:01:
In response to Re: Pump won't build pressure above 50lb in new pressure tank
: Unless the water is leaking out somewhere, the pump is the problem. If it takes a long time to build pressure and/or will not reach the full pressure point, the pump is not operating to its full design capacity. The only other possibiility is that it is pumping properly, but the controller and gauge are not registering the actual pressure, in which case you could be seriously overpressurizing the tank and system and stressing the pump.
I tried two different switches and made sure the guage on the tee was reading the same as the valve on the pressure tank so it does not look like that is the proplem. Is it difficult to replace a well pump?
Replies to this post
