| Posted by Drew McCann on March 07, 2004 at 09:28:17: | |
| In response to Re: Pump won't build pressure above 50lb in new pressure tank | |
BTW.. I also adjusted the pressure switch and precharge pressure in the tank accordingly. The pump just won't build pressure to the old cutoff of 70... just stays on at about 52 lbs. So i had to adjust everything down to fit it until i fix it. Current settings: swtich is at 28/48 and precharge is at 26. |
