Installing new tub
Posted by reggid on March 06, 2004 at 18:40:29:
I'm putting in a new tub and the new drain is not over the water waste line. There is a pea trap but it is not located under where the new tub drain is located. Does the pea trap have to be directly under the tub drain or can I run pvc pipe at a downward angle and tap in to the existing pipe where the pea trap is. If so how much pitch do I need per foot in order for it to drain properly? It's about a 3 foot run.
Replies to this post
