| Posted by Deb on March 06, 2004 at 16:07:20: | |
| In response to Re: HELP - Noise seems to be eminating from pipes | |
: Deb, I have checked that valve. There is no water coming from there. However, while the water was turned on, both pipes felt as if water were running through them and the left pipe was hot. After turning off the water heater at the breaker, the loud sound was still eminating from what seems to be behind the wall. : : : Thanks for the reply, Deb. What is a T&P valve? Where would I look for this? I have called a plumber. I am awaiting their slow arrival. : : : Kat : : : : : My husband thought I was crazy. For some time I had been hearing what sounded like water running. After triple checking every faucet inside and out, I could not locate the running water. I first heard it in the master bath. : : : : : Last night, just after dinner, the sound was so loud that it could not be ignored. It sounded as if it were eminating from the water heater. A walk through the house produced no clues. The sound was very loud by the water heater and in the master bath. Checking the pressure valve on top of the water heater didn't help. Turning off the power to the water heater didn't help either. Turning off the water at the main valve produced the quiet I wanted. We left the water off during the night. : : : : : This morning, we had to turn the water on for a shower. After the shower, I entered the garage to find water flowing down the garage floor. It didn't seem as if it was coming from the water heater, but I don't know for sure. : : : : : The water heater is about four to five years old. The house is about 14 years old. We have owned it for six and a half years. : : : : : Please, could someone tell me what the problem is and the best way to rectify this situation? : : : : Where does your T&P valve terminate? The water in the grage is most certainly coming from the water heater or a hot water line. Unless this is the T&P valve, it is impossible to trouble shoot this remotely. Call a plumber. : : Kat--the T&P is the temperature and pressure relief valve, located on the top or side of the heater with a toggle thing on it and piped through the wall to an appropriate location. If the water is escaping through there, you can usually feel the water going through the pipe and the pipe will be hot. The same thing if you have a leak on a hot water line, you can feel the water traveling through the hot outlet (left side) and the pipe is hot. Kat, I had a call. Hope your plumber has arrived by now. Most likely a broken pipe in the wall--something that you are going to want a plumber to take care of. Post back and let us know what it was. |
| There are none. |
