| Posted by Deb on March 05, 2004 at 19:55:53: | |
| In response to Re: offset in main stack vent | |
: : Generally, vents should not be offset horizontally below the flood rim level of the fixtures they serve. : : Deb : : The Pipewench : Thanks Deb. That's also what I inferred from the reading I've done. The problem is that I think the previous remodel moved the original wall so now the main waste stack lines up about 2 feet inside the bathroom floor, so no direct vertical path is available from the top of the waste stack to any point above the fixtures. : With my remodel the sink & the toilet will have separate venting that won't offset till they're above the fixtures. The trap arm for the tub/shower has a short run to the stack and I wasn't going to give it a separate vent. Should give it a vent line anyway to avoid issues? : Thanks, I know this would be easier with pictures! You can 90 a waste stack. You cannot 90 a vent stack. If there is plumbing above on the stack you want to tie the tub shower into, it must be vented. Otherwise this constitutes wet venting between floors. |
| There are none. |
