| Posted by Terry Love on March 05, 2004 at 02:08:10: | |
| In response to Re: WIGGLY COPPER PIPE | |
![]() : I changed the valves to the copper supply lines portruding from the concrete slab. After I replaced them, I noticed that one of copper lines, which portrudes from the concrete slab, wiggles from side to side. It's insulated with foam/plasticI. It almost feels as if the pipe is broken? Is this normal? There's no visible leak from the slab. Should I call a plumber to check the wiggly pipe? David David,
| There are none. |
