Re: Flapper Mystery
Posted by hj on March 04, 2004 at 17:46:16:
In response to Re: Flapper Mystery
No. The styrfoam is always under the water so it makes no difference where it is positioned as far as creating lift on the flapper. Lowering the float will increase the flush time and the amount of water used for the flush.
: I had installed a new Crane wall mounted (1.6 gal/flush) toilet 5 months ago. A slow leak has begun from the tank into the bowl on one side. The flapper looks to be in good condition, but I am puzzled by the round styrofoam ball which is attached to the flapper chain. It is adjustable up and down on the chain. What is this for? None of my other flappers were attached to a float. If the ball is moved lower, will this increase the pull on the flapper and make it more likely to leak? I can't find a replacement flapper for this assembly, but Crane has cheerfully offered to send a free replacement.
: Thanks,
Replies to this post
There are none.
