Re: installing a garbage disposal
Posted by hj on March 04, 2004 at 08:14:53:
In response to Re: installing a garbage disposal
Some of the small GE Disposals are fairly short. You might measure one of them. Or check the GE web site for dimensions.
: Had a nine inch deep sink installed with granite counter top. Due to the depth of the sink the the discharge outlet on the garbage disposal is not above the drain pipe in the wall. I understand it has to be at least 1/4 inch above the drain. Cannot seem to find a disposal with a discharge hole higher than six inches, need one at about five. Tearing out the existing drain is not an option. Anyone know of a disposal with a higher discharge hole.
Replies to this post
There are none.
