Re: House renovations info
Posted by Gary Swart on March 02, 2004 at 13:42:29:
In response to Re: House renovations info
As the three plumbers have said, don't pour chemicals into you drain system. If it is clogged, get a pro to snake it properly. If the drain is not clogged, and you don't imply that it is, leave it alone. The inside of a sewer pipe really isn't filled with affluant as many people would envision. You flush, the water washes the "stuff" out and unless something that doesn't belong in a drain gets in, the pipe is empty. "It ain't broke, so don't fix it."
Replies to this post
There are none. |
