| Posted by Gary on March 02, 2004 at 11:08:07: | |
| In response to Re: Slow hot water | |
: : Hello, : : My name is gary. One of my tile customers has a problem with her shower in which the cold water works fine but put it on hot and the water barely comes out. I put in a new cartridge for her thinking maybe it was just old, but the same thing is still happening. Does she need to have a plumber come and change the pipes or could there be another explanation? : : Thanks for your help. : Did you flush the lines? Is this a pressure balance with a balance spool? Did flush the lines and the hot H2O wss obviously not as strong as the cold but didn't seem bad enough where it couldn't push the water through the valve. It barely trickles out on hot though. The valve is an old original, the cartridge just a skinny simple thing. |
| There are none. |
