Re: Slow hot water
Posted by Gary on March 02, 2004 at 10:58:59:
In response to Re: Slow hot water
: : : Hello,
: : : My name is gary. One of my tile customers has a problem with her shower in which the cold water works fine but put it on hot and the water barely comes out. I put in a new cartridge for her thinking maybe it was just old, but the same thing is still happening. Does she need to have a plumber come and change the pipes or could there be another explanation?
: : : Thanks for your help.
: : Did you flush the lines? Is this a pressure balance with a balance spool?
: : Deb
: : The Pipewench
: Yes, did flush the lines and the shower valve is an old one with one of those skinny little cartridges. Not very complicated. Also, when lines were flushed, it looked like the hot water side was running a little slower but not so much that it couldn't push water through the valve.
Replies to this post
There are none.
