Re: downstairs toilet bowl
Posted by hj on March 02, 2004 at 08:47:18:
In response to Re: downstairs toilet bowl
The toilet or sewer line is still plugged. Plunging does not always cure the problem and often just packs the obstruction tighter.
: I have 2 upstairs and 1 downstairs,the bowl down stairs became clogged after 20 minutes of plunging, it became unglogged,my problem now is it does flush corectly,the water doesn't circle the bowl at all(where the water cmes out under the rim)and it sounds like i have air in the lines and air bubbles come up after it trys to flush. also the water will go up and down two or three times before its stops. Thanks for your time Scott
Replies to this post
There are none.
