Re: downstairs toilet bowl
Posted by e-plumber on March 02, 2004 at 06:55:13:
In response to Re: downstairs toilet bowl
: I have 2 upstairs and 1 downstairs,the bowl down stairs became clogged after 20 minutes of plunging, it became unglogged,my problem now is it does flush corectly,the water doesn't circle the bowl at all(where the water cmes out under the rim)and it sounds like i have air in the lines and air bubbles come up after it trys to flush. also the water will go up and down two or three times before its stops. Thanks for your time Scott Reply: If the toilet was flushing good until recently, I would suggest using a closet auger to snake the toilet. There could be an object stuck inside the toilets trapway. Good Luck. e-plumber
Replies to this post
There are none. |
