| Posted by hj on March 01, 2004 at 08:58:10: | |
| In response to Re: Code | |
The code is irrelevent. You have to find the manufacturer's requirement. If that is more than the "code" it is still what you will have to use. And it will not be less than any code requirement, in any case. : Where can I find the code in Louisville KY for the clearance needed between the cooktop and the bottom of micro?
| There are none. |
