Re: How to measure water pressure?
Posted by Deb on February 29, 2004 at 16:43:37:
In response to Re: How to measure water pressure?
: The hot water line in my building has too much sediments I was said and contractor wants to replace the whole line. Is there a gauge to measure resinential water pressure? Thanks PSI is PSI, not matter how small an opening it is coming from. Chances are that you have a volume problem from build up on the internal walls of the pipe and fittings. Pressure is most likely not your problem and a pressure gauge will tell you nothing. Deb The Pipewench
Replies to this post
There are none. |
