Re: Leaking Water Heater
Posted by jimbo on February 29, 2004 at 15:05:09:
In response to Re: Leaking Water Heater
:You need to do a little detective work and identify exactly where the water is leaking.
It is possible for a fitting, such as the nipples on top, the TP (relief) valve, or the drain valve to develop leaks.
If water is leaking out of the bottom of the tank, that is terminal.
Replies to this post
There are none.
