| Posted by hj on February 29, 2004 at 09:57:34: | |
| In response to Re: moving a vent stack | |
Besides the limitations as to how you can offset the pipe, you may find that once you open the floor, the existing fittings are such that doing it will be impossible without a major repiping. : Currently my vent stack run through my batchroom in a small partition wall. When I redo the bathroom in a few months I plan to remove the wall but I will have the vent pipe running throught the floor out to the roof. The pipe is only 6 away from the side wall now. Can I have bent in the pipe that was below the floor so I could move the pipe it to the next wall.
| There are none. |
