| Posted by hj on February 29, 2004 at 09:55:26: | |
| In response to Re: Basement rough in | |
Since it is horizontal, the probability is that it was intended for you to install the trap once the necessary location for it was established. : I am finishing a basement in a 10 year old home with plumbing already roughed in by builder. There is the toilet drain and two vent pipes but there is a 14 x 14 inch hole in the concrete floor that was filled with styrofoam. I removed this to find a 2.5 inch DWV stub running parallel with the floor (capped) about 12+ inches deep from floor level. To install my bath will I need to put a trap on this or could there be one in the concrete already? How do I tell?
| There are none. |
