: Currently my vent stack run through my batchroom in a small partition wall. When I redo the bathroom in a few months I plan to remove the wall but I will have the vent pipe running throught the floor out to the roof. The pipe is only 6 away from the side wall now. Can I have bent in the pipe that was below the floor so I could move the pipe it to the next wall. Most likely not. Vents cannot 90 below the flood rim level of the fixture. There is a reason for this. You should call a plumber and see what your options are. Deb The Pipewench
