| Posted by hj on February 28, 2004 at 09:51:15: | |
| In response to Re: washing machine hookup | |
You have a "Mickey Mouse" drain connection. There is not supposed to be a "clamp or grip to keep spillage in the drain". If you have one, then it must be because the drain in the wall is defective and cannot accept the normal water discharge from the washing machine. Rather than trying to make the drain tighter, which will overload the washing machine pump and possibly cause it to fail, have a plumber check the drain line to see what its problem is. : : My washer has a plastic hose that goes into the "drain" or "pipes" on the wall in my basment. The water should spin out and go through the hose and into the pipe. However, the "clamp" or "grip" that should leave no room for "spillage" isn't working properly. I changed it by getting a rubber hose and two small clamps in an attempt to force the water to go straight into the drainage pipe and not overflow or spill out, but it still isn't working. What should I do? : Reply:
| There are none. |
