| Posted by Deb on February 26, 2004 at 17:59:35: | |
| In response to Re: sanitary tee | |
: i've read here that a sanitary tee can only be used in a vertical position. I have 5' extentions to two fixtures (a wet bar sink and a lav), the lav is in the center and i have laid a sanitary tee horizontal to stub out this center fixture. is there some other fitting i should use? San tees cannot be used in the horizontal. Use a wye and a 45 or a combination fitting. |
| There are none. |
