: i've read here that a sanitary tee can only be used in a vertical position. I have 5' extentions to two fixtures (a wet bar sink and a lav), the lav is in the center and i have laid a sanitary tee horizontal to stub out this center fixture. is there some other fitting i should use? Reply: The correct fitting to use on a horizontal drain line would be a wye with a street 45 to make the stub out square. A regular ty or sanitary tee would prevent proper flow. ...What are you doing about venting? Good Luck. e-plumber
