| Posted by Gary Swart on February 25, 2004 at 19:01:53: | |
| In response to Re: Turning a toilet | |
Even if you can manufacture enough space for side clearance and don't mind the wide space behind the tank, the flange bolt holes will not match the tank bolt holes; they will be 90 degrees off. If you can manage the space requirements, take up the floor and redo the drain to fit the location properly. The CI will make the job a like more interesting that if you had plastic, but that's how it goes. |
| There are none. |
