Re: Turning a toilet
Posted by kevin on February 25, 2004 at 14:39:11:
In response to Re: Turning a toilet
: No. For one thing the pipe is only 12" or so from the back wall and should be at least 15" from the side wall so if you just rotated it 90 degrees, it would be too tight on the side and a long way away from the wall at the back.
: : I'm remodeling a basement powder room into into a full bath and need to turn the toilet 90 degrees. It has a cast-iron flange and soil pipe. Is there a way to turn it without tearing up the floor? Please help....
The wall is coming out and the water supply is being relocated. Is there a way to turn a toilet with a cast-iron flange and soil pipe 90 degrees without tearing up the floor?
Replies to this post
