Re: Delta Monitor, low shower pressure
Posted by holla on February 25, 2004 at 13:13:14:
In response to Re: Delta Monitor, low shower pressure
: The shower head may be clean but it has a flow regulator to keep it from using too much water. Most flow regulators are built into the shower head and cannot be removed.
: : I lava a Delta Monitor (single handle) in my shower. The water that comes out of a spout has good pressure, but when I switch to a shower, it has hardly any pressure. I checked the shower head, and it is clean. If there is problem with the pressure regulator (or whatever the heck it is inside the spout) any suggestions on how to take it apart and fix it would be much appreciated.
: : Thanks
: : Alex
Replies to this post
There are none.
