| Posted by hj on February 25, 2004 at 07:44:18: | |
| In response to Re: Second water heater | |
If you can pipe two heaters 25' apart in parallel and make them work properly, you would not only be a genious, but you would have to install a "ton" of pipint. Either install them in series or separate the two systems and use one water heater for each. : I want to add a second water heater since we use a bunch of hot water all at the same time in the morning. The one I currently have I about 5 years old and in good shape, so I really don't want to replace it with a better recovery model. I was going to add a second gas heater in the garage about 25' away from the existing gas heater in the laundry room. Should I plumb them in series or parallel them for the best result??
| There are none. |
