| Posted by David Steinberg on February 24, 2004 at 13:22:21: | |
| In response to Re: DWV Pipe gap and Fernco | |
Yeah, I'm following-up on my own followup :) I just came to realize that the original setup is not to code, in that the vent is upstream of the bend. What I need to do is put in a wye, connect a toilet bend to the straight line, and use 45's to jog around the bend to the vent side, which will place the vent properly. Do you folks think I can do this as a full glue-up? : : : : You should have used 2 ferncos. I wouldn't leave a gap like that. : OK then, what should the coupling and fitting be?
