Re: Joining Cast Iron to PVC
Posted by Chris on February 24, 2004 at 11:50:32:
In response to Re: Joining Cast Iron to PVC
: Yes, if for no other reason that it has the metal band around the outside to stabilize the pipes and prevent them from shifting out of alignment which can happen with the Fernco. In this area, and depending on the location of the pipe, it may be the only accepted way. Thanks for your help, hj, as always. You make a good point about the metal band; I was a little worried about the plastic sliding sideways off the bottom of the iron stack.
Replies to this post
There are none. |
