| Posted by David Steinberg on February 24, 2004 at 10:03:24: | |
| In response to Re: DWV Pipe gap and Fernco | |
: : : You should have used 2 ferncos. I wouldn't leave a gap like that. : He couldn't legally install a san tee if it was going to be inspected, and you should not have used one either. The pipes should be cut square and the inserted piece should fit tightly to the existing pipe. A Fernco is also not the proper/legal coupling to use either. OK then, what should the coupling and fitting be? |
