| Posted by Chris on February 23, 2004 at 22:28:03: | |
| In response to Re: Joining Cast Iron to PVC | |
: You did not have the proper Mission coupling. You needed one for sch. 40 PVC to cast iron, either extra heavy cast iron or Service weight, depending on which you have. Thanks, hj. I suspect you are right. The one I had was probably for the extra heavy, and I've got the service weight, as it is actually smaller in diameter than the PVC. I have two additional questions, if you don't mind: 1) Is this a substantially better solution than the Fernco? 2) Is this code approved (UPC)? |
