Re: Wall Mount toilet
Posted by hj on February 23, 2004 at 16:54:15:
In response to Re: Wall Mount toilet
The residential models do have tanks. The fitting to support the toilet may require a thicker wall than you are planning. The major advantage is ease of cleaning.
: Is there any advantage from a plumbing stand point to consider a wall mount toilet? We are remodeling a master bath. We're adding 2 ft to the existing room. We are on a slab. We will be moving the toilet about 2 ft. The floor will have to be jacked up to move the drain.
: Are they vacuum-assisted since there is no tank?
Replies to this post
There are none.
