| Posted by GregO on February 23, 2004 at 16:03:37: | |
| In response to Re: attaching pedestal sink to wall | |
Mike, You are correct about the bracing. Drywall anchors are the quick and easy way, but not ideal, especially if you have kids (or the chance of kids) crawling/hanging on it or even frail people that use it. Overengineering here is a good idea. Do it once and it's done. Good luck and have fun, Greg : Hi everyone. I need a little advice on attaching a pedestal sink to drywall. The sink is an American Standard Cadet and has no bracket, just the holes in the in the back of the sink itself. The insturctions say to add a 2x6 support in between the wall studs behind the drywall to support the sink. The soon to be half bath is 32" wide and thus there is only one stud right in the center of the wall. So, I am assuming I would add one 2x6 brace on each side of that center stud and connect the other ends with the studs that make up the corners of the wall. Correct? : BUT,
| There are none. |
