Re: Does sewage ejector need GFCI outlet?
Posted by ED on February 23, 2004 at 15:57:03:
In response to Re: Does sewage ejector need GFCI outlet?
Conventionally, a 20 amp dedicated circuit with a single (round) outlet for the pump is installed.
Use 12-2 w/G for the cable. It must be housed in metal conduit if installed in unfinished basement.
: : I have installed a sewage ejector in my basement. Does it need to be plugged into a GFCI outlet? If the circuit trips and I don't know, I could be in trouble. Thoughts?
: Reply:
: A properly grounded receptacle is required with its' own circut breaker. A GFCI is not required by code but some manufacturers suggest one for "added safety".
: Good Luck. e-plumber
Replies to this post
There are none.
