| Posted by David Steinberg on February 23, 2004 at 13:33:51: | |
| In response to Re: DWV Pipe gap and Fernco | |
: You should have used 2 ferncos. I wouldn't leave a gap like that. : Wasn't it an option to simply cut out the flange and extend the trap arm? : Deb : The Pipewench The drain runs directly under the toilet (about 10" below floor grade), so the trap arm is vertical. The contractor apparently measured for a santee, and then he put in a wye and a 45. I had to reach in and make a fairly not-square cut on the upstream pipe, so even if I butt them up there will still be about a 1/2" gap (on the bottom, of course). Given that, would it pay to chop out that nice glued coupling and add a downsteam Fernco? |
