| Posted by Deb on February 23, 2004 at 10:44:31: | |
| In response to Re: Wall Mount toilet | |
: Is there any advantage from a plumbing stand point to consider a wall mount toilet? We are remodeling a master bath. We're adding 2 ft to the existing room. We are on a slab. We will be moving the toilet about 2 ft. The floor will have to be jacked up to move the drain. : Are they vacuum-assisted since there is no tank? Many wall mount toilets have tanks. What brand and model are you looking at? A flushometer takes a 1" water lines, which normal toilets do not have. I don't think you are going to gain anything putting in a rear outlet toilet--the floor is going to have to be jackhammered to access the old drain. |
| There are none. |
