| Posted by ew on February 23, 2004 at 10:38:52: | |
| In response to Re: priming a shallow well water pump | |
Josh, Sometimes can take a minute or two to pick up. I have also found that there are times I will prime it let it run for about a minute and then reprime. Possibly repeating several times. : Can someone explain step by step on how to prime a water pump. I understand you have to fill the pump with water, but what I don't know how to do is bleed the line( get the air out so the pump can catch). Thanks
| There are none. |
