| Posted by Nicholas Juliano on February 20, 2004 at 20:06:34: | |
I CAME ACROSS A HOT WATER SYSTEM WITH TWO HONEYWELL V8043E ZONE VALVES AND AN L8148 G RELAY....I HAD TO CHANGE A ZONE VALVE HEAD AND RAN INTO A BIND...THERE WAS NO SEPERATE TRANSFORMER ON THE JOB AND WITH THE LOW VOLTAGE TERMINALS T TV AN Z WERE THE ONLY ONES TO WIRE TO....AFTER I TOOK CARE OF THE YELLOW LEADS TO ONE END OF THE TSTATS AND THE OTHER TO ONE LEG OF THE TRANSFORMER IN THE RELAY, WHERE DO YOU PUT THE RED WIRES? |
