Re: New basemant bathroom
Posted by Deb on February 20, 2004 at 15:26:14:
In response to Re: New basemant bathroom
: I want to install a bathtub on a cement basement floor. The drain pipe is 2" and goes directly into the floor. How can I install the tub right on the cement fllor and catch the drain? Common sense tells me that I must bust up and remove the cement and make a path from where the drain comes out of the tub and go deep enough for a "P" trap. Is this correct? or is there another way? Thanks You also need to vent the tub. The vent must go between the p-trap and the connection to the main drain. Your local code will dictate the maximum the vent can be from the p-trap. The vent needs to run out through the roof by itself or join with another vent 6" above the flood rim level of the highest fixture that vent serves. Deb The Pipewench
Replies to this post
There are none. |
