| Posted by Deb on February 20, 2004 at 15:20:43: | |
| In response to Re: bath tub drain | |
: I had a new bath tub drain put in a year ago and it is stopping up. The stopper just turns around and around and it will not unscrew. Don't all the new ones come off so you can clean or run a snake down it if necessary.? : Please help!! First pull the stopper all the way up and see if there is a screw or a set screw that you can see under the large round part of the drain. If so, loosen and things will come apart If not... |
| There are none. |
