Re: Serious Drain Issues!!! HELP!!!!
Posted by Deb on February 19, 2004 at 00:43:13:
In response to Re: Serious Drain Issues!!! HELP!!!!
: I live in a mobile home. My problem is this. When I use my washing machine (which is adjacent to my bathroom)my bath tub fills with water, my toilet bowl bubbles and fills up and a small amount of water leaks out where the wax ring seats to the floor, and the drain pipe of my CWM overflows onto the floor. I have not noticed any sewage back up or odor. I notice the water in the tub is from the washing machine due to the color and the "fuzz" content. After this happens, it takes hours for the bath tub and toilet to drain down. I have so many opinions from people, I thought it was time to ask a pro!! Please help if you can! Thanks! It is pretty amazing that the toilet, tub and sinks are draining when used alone, but use of the washing machine causes everything to clog.? You must have a main drainage line clog. It could be an easy fix or a tough fix. Only a pro at the scene can give you an answer. Do not use chemicals like Drano. They do not work and are harmful to people, pipes and equipment. Deb The Pipewench
Replies to this post
There are none. |
