Re: Modulate temperature with well water circulating under floor?
Posted by Deb on February 18, 2004 at 20:23:05:
In response to Re: Modulate temperature with well water circulating under floor?
: I'd like to modulate the temperature of a cabin. If I put plastic or PEX pipes under the flooring and run the shallow well pump continuously, will that work? I'd return the water to the well after the heat transfer. If it might work, where can I find heat loss tables to determine the type/size of pipes needed (e.g., with a 30 degree air-water difference, a 3/4" inch plastic pipe looses 1-degree every 10 feet)? This will most likely not work. Unless you are in some geothermal area, there is simply not enough heat to do any kind of good. What is the temp of your water? I don't think much about returning "used" water into a well. The best thing you can do is to make sure that the space under the cabin is absolutely tight. A crawl space that lets absolutely no cold air in stays amazingly warm from the ground heat. We went under our place and sealed every single little tiny space that let light in. Deb The Pipewench
