Re: Moving toilet 2.5 inches
Posted by Deb on February 18, 2004 at 20:12:22:
In response to Re: Moving toilet 2.5 inches
: In my small bathroom, a replacement tub system will reduce my sidewall clearance to the toilet flange to about 10.25" OC. It was always a tight space with the old sidewall clearance at about 12" OC to the flange with the old tub. My question is: What would be the easiest way to offset the toilet about 2.5" from the wall? This is an older home with cast iron flange about 2ft in length into a vertical lead connection, directly below the current stool position. I might add that the cast iron flange is broken at the normal mounting slots and the flange is intact fore and aft. Any suggestions will be appeciated. Thanks, Herf
I would recommend that you rethink your tub selection. Minimum side to side clearance is 15" from center of flange to wall or other obstruction.
The Pipewench
Replies to this post
There are none.
