Re: Bathroom Floor Leak
Posted by e-plumber on February 18, 2004 at 15:03:52:
In response to Re: Bathroom Floor Leak
: I am a renter in a home and there seems to be a leakage in the floor. The did something with the toilet, yet the floor is still wet. (you don't really notice it until you lay a towel or rug over the floor) The rugs and towels become soaked and never dry up. What do you suppose is the cause. Will it be an easy fix or an expensive one? In addition, the wetness seems to get onto the carpet outside of the bathroom, although it's a little dry now, i don't know if it'll return.
Reply:
There is no telling how much the repair will cost. Whoever "did something with the toilet" should return to correct the leak. The dampness could be from several areas; the toilets' close coupled kit, supply line, shut off valve, a defective toilet seal (wax ring) or even a clogged drain line below the floor.
Since you are a renter, tell the Landlord to have it repaired ASAP before mold starts to form.
Good Luck. e-plumber
Replies to this post
There are none.
