| Posted by e-plumber on February 18, 2004 at 13:55:01: | |
| In response to Re: Solid-Surface Shower Pan Drain Fitting | |
: Although manufacturers of solid surface shower pans do not seem to mention it, I have seen several plumbing experts on the web still recommend installing some sort of membrane shower pan underneath the solid surface formed pan. Most say this is protection against sweating and added insurance for any leakage around the drain and pan at the walls. : I would like to do this for the SwanStone pan I am installing; however, I have yet to find an appropriate shower drain fitting that will clamp to the SwanStone pan drain and also provide for the attachment of a membrane pan underneath. My drain system is ABS pipe. Everything I find is for ceramic tile installations it seems. : Does anyone know of a particular manufacturer and model of fitting I can procure? : Thanks -- Watson Reply: |
