| Posted by David on February 17, 2004 at 20:02:25: | |
| In response to Re: Tub Drain | |
Thanks e-plumber. I do have an overflow outlet in the tub and I was wondering if a proper connection would have the overflow pipe connected to the drain pipe? Maybe that connection would hold the drain pipe in position? Rather than taking a chance, I will leave well enough alone until I have real problem! : : I have a fiberglass shower/tub unit approximately 10 yrs. old, and I would like to replace the drain fitting in the tub (the chrome plating has worn off). I do not have access to the connection from behind or below the tub. : : It appears as though the drain pipe directly under the strainer makes a very sharp bend (appears almost flat) heading back under the tub. : : If I were to remove the drain connection by twisting it out by the strainer, what is the likelyhood that the drain pipe will drop out of position, causing a problem? : Reply:
| There are none. |
