| Posted by hj on February 16, 2004 at 13:51:50: | |
| In response to Re: Pipe Material and Diameter Question | |
For that distance I would suggest at least 1 1/2" pipe and 2" would be better since the added cost would be minimal. Using a smaller pipe with a booster pump would not help a lot, since the water flow would be restricted and then the booster would pull a vacuum causing other problems. : I have a water well on my property. I need to run pipe from my well to my homesite. It is about 1700 feet - about a 10 foot incline. The well has a 50 gallon pressure tank and puts out about 60 psi. The well has a 1 1/2 external pipe fitting. Three questions please: : 1. What size pipe should I run to my home? : Thanks a lot. : Mike
| There are none. |
