Re: removing a fitting from a cast iron radiator
Posted by hj on February 16, 2004 at 10:05:15:
In response to Re: removing a fitting from a cast iron radiator
If you just broke the nut and the tailpiece is still in the radiator, unscrew it. The nut often has to be cut off to remove that piece from a cast iron radiator.
.: I need to remove a fitting from a cast iron radiator. I broke the nut that is captured on the U fitting (on the bottom end of the radiator) that threads onto the pipe coming from the system. Any ideas???
: Thanks...Kevin
Replies to this post
There are none.
