Water tank noise from new
Posted by Bernie on February 15, 2004 at 23:53:35:
Electric hot water tank. Maybe 30 psi water pressure in tank as is gravity feed system from above ground well. Age of tank-month . Makes a noise that sounds like water boiling from element. Goes on and off. Should it make that noise? Reason to be concerned? Tank is located on main floor can be heard from all rooms(kinda like the fridge if it is new for you). Noise sounds like a shhhhhh. Any ideas??
Replies to this post
There are none.
