| Posted by hj on February 14, 2004 at 18:31:34: | |
| In response to Re: mobile home-water line problem | |
Since this is a double wide home, and if the plumbing for the washer is on a different side than the rest, then the pipes joining the two halves may have been capped and then not reconnected after the move. : recently moved mobile home 16X56, hooked up water line as it was when moved, now...i have no water in either bathroom sinks, and no water in either toilets, and also only have hot water to washer...no cold water there now.....what have i done wrong here? can someone help me?
| There are none. |
